Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
“Continue” command for dimensions in the Revit,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I’m not sure if there is a command like what we have in the autocad regarding the dimension “continue”
Where it might be in the Revit?
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Re: “Continue” command for dimensions in the Revit,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
dimensions are automatically continuous.
Scott D Davis
AEC Technical Specialist
North American Sales
Want Revit Content? Go to http://seek.autodesk.com !
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
thank you for the answer.
The issue that, the help, has no screenshots and thus no visual impact which can better assist in catching the whole idea fast.
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is no such tool. As Scott said, the dimensions in Revit are intended for continuous operation. Each consecutive click finds a new point for the next dimension segment, and each successive dimension is grouped with the first into a single entity until the tool is restarted.
The link that was posts did not have images, but it did have two good videos. The "Dimensioning Tools" video will give you a good idea of the intended workflow with Revit dimensions.
⁞|⁞ Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As others have said, dimension strings are automatically continued when you are first creating them. However, if you've finished a string (accidentally or intentionally), but would like to extend it further, select the string, then in the Modify tab choose "Add witness lines", then click on whatever else you want to dimension to.
Similarly, if you've finished a dimension string, and want to remove some items from it without recreating the entire string, select the string, then right-click on the little blue dot that is about halfway between the dimension text and the object being dimensioned, and choose "Delete witness line".
Better yet, read the wikihelp on dimensioning.
BIM Manager
Arcturis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Many thanks guys for the help. Your contribution is quite useful.
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
