Autodesk Revit Architecture
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Constrain 3D view to Scopebox
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi
I would like to constrain a 3D view to a scopebox like I can do with planviews. How can I do this?
Kind regards
Peder
Re: Constrain 3D view to Scopebox
- Highlight
- Email to a Friend
To do that, you would use section boxes in 3D (found in the properties palette). Eventually, you can later on even lock the 3D orientation from the view control toolbar at the bottom which would then enable you to annotate even the 3D view.
Structural Design Engineer
MZ & Partners Engineering Consultancy
- Highlight
- Email to a Friend
Hi
Thanks for replying.
I am aware of the functionality of section box, but I want to lock the section box to a scopebox.
In that way, I can send my model to Robot for analysis and get my building aligned to the xy axis.
I cannot rotate project north because this ruins all of my section views.
- Highlight
- Email to a Friend
Hi again. There is no option for defining a scope box to 3D views. It is available for plans, sections, and elevations. By the way, why do you need to align the robot model to the XY directions?
- Highlight
- Email to a Friend
I want to do for the reasons mentioned in this post: http://forums.autodesk.com/t5/Autodesk-Robot-Struc
- Highlight
- Email to a Friend
Hi. I don't know if this solves your problem but here is what I did.
1- send the revit model to robot.
2- rotate the model in robot.
3- conducted analysis ...
4- updated the revit model.
5- the revit model is now rotated and set to project north
6- changed my view back to true north
I'll continue checking to find alternatives and let you know if I find any workaround.
Regards.
