• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Composite Walls vs Built-up walls
    149 Views, 0 Replies
    08-22-2012 02:02 AM
    I am after advice on how best to build-up complext external walls that will comprise multiple trades and allow the specialist cladding elements to be replaced by the subcontractor modelled elements: eg I have:
    1. Internal plasterboard lining
    2. metal structural framing with insulation between - specialist design and install
    3. sheathing board - specialist design and install
    4. cladding system - specialist design and install
    I can do this to a degree with a Composite walls, but each element will stop and start in different places and each will be installed by a different trade.
    is it better to model separately to get better output from QTO and to allow for the replacement of specialist models?
    Please use plain text.
