• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    Column-Wall snapping,
    277 Views, 6 Replies
    10-07-2012 01:26 PM
    Column-wall snapping
    In the screenshots below, when moving a column, the snap (endpoint) is working from its corner to the corner of the wall, but this endpoint snap doesn’t appear at the corner of the indicated layer of the wall!
    Why there is no endpoint snap there?
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Active Contributor
    arya2013
    Re: Column-Wall snapping,
    10-08-2012 01:04 AM in reply to: JamaL9722060
    Hi You can do it with the Align tool
    JamaL9722060
    10-08-2012 12:32 PM in reply to: arya2013
    Many thanks for the help and the screenshot,
    Snap is much easier than doing this with “align”!
    Why the snap is still weak in the Revit? Snap is as the “soul” when it comes to drawings.
    Firefox 20.0,
    Kaspersky 2013.
    Valued Contributor
    10-08-2012 01:25 PM in reply to: JamaL9722060
    Place intersecting column grids in your plan at the locations you want. The columns will snap to the grid intersections.
    CDV
    JamaL9722060
    10-08-2012 01:37 PM in reply to: cvandevere
    Many thanks
    What such difficult issue to have a snap at that corner of the wall?
    Is this problem still in Revit 2013?
    Firefox 20.0,
    Kaspersky 2013.
    Valued Contributor
    10-08-2012 01:53 PM in reply to: JamaL9722060
    I haven't tried to snap column to a wall to in 2013. My work flow is a little different, I place my column grids then add columns then add walls. I can insert walls at corner point or center point of a column if I wnat too.
    CDV
    JamaL9722060
    10-09-2012 02:18 PM in reply to: cvandevere
    Many thanks for the answer.
    As you know, many architects don’t start by grids! And thus columns are placed and then centre lines are then set. I’m talking about this case in particular.
    I have the impression that the Revit needs a lot of enhancement in snaps.
    Firefox 20.0,
    Kaspersky 2013.
