@robert.noriega
You most likely have figured this out by now, but for any future readers of this thread, you can modify the visibility of extrusions in a column family by:
- Edit the family.
- Select the extrusion.
- On the Modify|Extrusion contextual ribbon tab, on the Mode panel, select the Visibility Settings tool.
- In the Family Element Visibility Settings dialog, in the Detail Levels area, check the toggles of the Detail Levels for which you want that extrusion to be visible.
- Select OK to accept the change.
- Save the family, if appropriate.
- Load the family into the project(s) where you want to see the change.
In the out-of-the-box imperial wide flange column family, the extrusion is only set to be visible at the Fine Detail Level.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
