• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Accepted Solution
    Column Display at Different Display Levels
    135 Views, 1 Replies
    11-01-2012 07:50 AM
    Hi
    Does anyone have a quick explanation of how to make columns display as columns in the coarse level of detail instead of just as sticks?
    I know I'll have to edit the family but I can see anything obvious to change.
    Regards
    Christopher Alan Pitt
    Frank Shaw Associates
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: Column Display at Different Display Levels
    11-01-2012 08:14 AM in reply to: chris.pitt
    Open the column family, select the extrusion > visibility settings, > activate coarse. Now, do the opposite with the symbolic lines, making them Not visible in coarse level of detail.
    Planta1 Revit Online Consulting | info@planta1.com
