• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    Clean up on floor plan end walls
    151 Views, 1 Replies
    12-03-2012 11:24 AM
    In a floor plan how can I get the exterior material stucco to rap around the end and terminate at the intersection of the Store front and wood stud? The same question would apply with the interior drywall. The Wood stud wall is 6” the storefront is 4”, thus the need for the finish material to rap around the end of the stud.
    For future post.  For attached file is there a preferred or max file size?
    Please use plain text.
    Alfredo_Medina
    Re: Clean up on floor plan end walls
    12-03-2012 11:38 AM in reply to: cadmansteve
    Wall types have a property to wrap layers at ends, and at the insertion of windows and walls. But that does not apply for what you need to do for this wrap of the finish at the joint between a wall and a curtain wall.
    It is good practice for Revit walls to separate the structural part from the finish part. That means, creating the finishes with a thin wall type, independent from the core. This practice has two advantages:
    1) All these issues about wrapping, joining, extending layers, in plan and elevation, are easy to fix.
    2) For structural walls with finish, the engineer receives the structural elements, only, while the finish elements remain in the architect's model.
    Planta1 Revit Online Consulting | info@planta1.com
