• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Employee
    Check out the Self-Paced Guide “My First Plug-in”
    1669 Views, 3 Replies
    05-23-2011 02:51 AM
    Check out the Self-Paced Guide “My First Plug-in” presented by the ADN Revit Team
    http://www.autodesk.com/myfirstrevitplugin
    Are you an Autodesk Revit power user with an interest in becoming even more productive? Would you like to automate or extend the capabilities of Revit, but are new to computer programming? If so, then this guide is designed for you.
    “My First Plug-in” is a self-paced tutorial guide for a smooth introduction into the programming world. This is a “one-stop shop” learning path for users who know Autodesk products but are absolutely new to programming and are thinking about taking the plunge. In this guide, you will be working with the Autodesk Revit .NET API and the C# programming language. The supported product version is Autodesk Revit Architecture 2011 and succeeding versions.
    There are many resources available on the web for you to learn about the Autodesk Revit API (Application Programming Interface), however, these resources tend to be designed for people who already know programming. This guide is different: it assumes no previous programming knowledge and yet helps you build your first plug-in quickly, without swamping you with details. You’ll have a working application within an hour of starting this material, irrespective of your current level of programming expertise.
    The guide will start by reviewing the benefits of customizing Autodesk software before progressing onto lessons covering the use of the Autodesk Revit API. The lessons will start by building a working plug-in before covering more detailed explanations of the underlying principles and further developing the application’s functionality.
    Product: Autodesk Revit 2011 or higher
    Programming Language: C#
    Application Programming Interface (API): Revit .NET API
    If you have any feedback on this new guide let us know at myfirstplugin@autodesk.com
    Re: Check out the Self-Paced Guide “My First Plug-in”
    09-09-2011 06:25 AM in reply to: saikat
    looks great looking forward to trying it - I only have Revit 2010, will this be an issue?
    Employee
    09-09-2011 07:57 AM in reply to: saikat
    Hi Michi-Ken
    Thanks for the words of appreciation.
    Revit API had undergone some fundamental changes from Revit 2010 to Revit 2011 and so we will recommend that you use Revit 2011 (and higher) when you are trying out this guide.
    Good luck and hope you enjoy working with this guide. Feel free to get in touch with us if you have any queries.
    cheers
    Saikat
    Valued Contributor
    03-16-2012 02:26 PM in reply to: saikat
    I was planning on working through guide and I followed the link to install the Visual C# 2010 Express but the link offered the latest version of visual studio 11 beta which installs .NET4.5 beta. This version of .NET corrupted my ribbon and made Revit mostly unuseable so don't install the 2011 version it offers.
    Windows 7
    RAC2012
