• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    Changing the sheet border to another
    128 Views, 3 Replies
    01-04-2013 09:24 AM
    I created many sheets with a wrong border, can I reassign another  titleblock instead of making all new sheets from scratch?
    Please use plain text.
    Re: Changing the sheet border to another
    01-04-2013 09:35 AM in reply to: krybuk
    Yes. Click on the Titleblock in a Sheet, then in Properties you should be able to select another Titleblock Family--which should be loaded into the Project first.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Valued Contributor
    01-04-2013 09:47 AM in reply to: ccollins
    Thanks! How did I miss that?
    Employee
    01-04-2013 10:57 AM in reply to: krybuk
    and if you did many sheets: right click on one and choose Select All Instances, and then choose another loaded titleblock from the Type Selector in Properties.  No need to do them one by one.
    Scott D Davis
    AEC Technical Specialist
    North American Sales
    Want Revit Content? Go to http://seek.autodesk.com !
