• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    Change the level a floor plan view is associated to?
    154 Views, 4 Replies
    10-30-2012 06:59 AM
    Is there a way to change the level that a floor plan view is associated to?
    Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
    Please use plain text.
    Employee
    loboarch
    Re: Change the level a floor plan view is associated to?
    10-30-2012 11:48 AM in reply to: dtiemeyer
    Could you clarify what you are trying to accomplish?  The floor plan view is "generated" from the level datum.  There is not really a way to seperate the level from the floor plan.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    10-30-2012 11:54 AM in reply to: loboarch
    My user drew her HVAC system on the 'First Floor' and has it completely annotated, etc. The view is done 'being drafted'. Then the architect decides to move her equipment & mains from the First Floor to a 'Clerestory' Level that is 14'-0" above the First Floor. Therefore what I'd like to do is take all the elements in a view that are associated to First Floor and associate them to Clerestory while retaining their offset value.  I was thinking I could do this simply by changing the 'Associated Level' of the view, but now that I'm typing all this out, I realize all these are element settings.
    For that matter, how do I change what level a duct measures its offset to?
    If you understand the predicament, I'd enjoy hearing any suggestions. Thanks.
    Dustin
    Employee
    loboarch
    10-30-2012 11:58 AM in reply to: dtiemeyer
    You should be able to use cut and paste functions to cut the HVAC element s from one level and paste them into the same position on another level of the project.
    Jeff Hanson
    10-30-2012 12:12 PM in reply to: loboarch
    Yeah, I guess that seems to be the only way. Thanks.
