• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    benjamin.strong
    Cape/Colonial House Details Need Help
    171 Views, 1 Replies
    05-31-2011 08:56 AM
    Im relatively new to revit and I cant figure out how to add trim to the faces of buildings.  I know how to sweep a crown around the walls but vertical trim is what im struggling with.  Also how do you make a profile to sweep?  My last question pertains to wall sections.  How do you show a typical stacked wall section with blocks, joists,floors, rafters and roof?  WOuld you do all of this using the edit structure tool in type properties or would you do this in a callout?  Any advice, tips, or pointers would be great and very useful. Thanks.
    Please use plain text.
    Re: Cape/Colonial House Details Need Help
    06-01-2011 03:42 PM in reply to: benjamin.strong
    Posting your question in the Revit Architecture Discussion Group will likely get you a better response than here in the AutoCAD Architecture Content Discussion Group. http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/bd-p/133
    David Koch
