• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    popguyon99
    Cannot change dimensions !
    126 Views, 3 Replies
    02-03-2013 01:51 AM
    here attached with a picture captured my current issue, can somebody please help me??
    actually, the object is just a simple extrude, i don't how to make the dimensions editable, please help
    Please use plain text.
    Valued Mentor
    AJA14
    Re: Cannot change dimensions !
    02-03-2013 04:07 AM in reply to: popguyon99
    To be able to make dimensions editable, you need to select the object and not the dimension. When you do, the dimension turns blue and then you can click on the text and edit it.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    Member
    popguyon99
    02-03-2013 04:29 AM in reply to: AJA14
    so, i cannot build dimensions onto the drawing directly, and change the sizes by modifying the numbers?
    Valued Mentor
    AJA14
    02-03-2013 09:37 PM in reply to: popguyon99
    Yes you can. But to modify the dimension, you need to select the element that the dimension is driving, then click on the dimension text and it becomes editable. When you change the text the element follows.
    Ali Al-Hammoud
