• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    Can't import DWG or DXF files
    136 Views, 5 Replies
    01-17-2008 05:42 AM
    I get the same error message whenever I try to import third-party DWG or DXF files (both simple and complex): "Import detected no valid elements in the file's paper space. Do you want to import from the model space". The result is always the same - nothing appears in the workspace. Can anyone please suggest a fix?
    Please use plain text.
    *cdv
    Re: Can't import DWG or DXF files
    01-17-2008 06:12 AM in reply to: cjclarke
    I have never gotten message and have not try to import 3 rd party DWG file.
    Do you have access to a copy of Autocad or Autocad Architecture that you can
    use to open the file that you are trying to import to see how the file is
    actually laid out? Make sure the drawing within autcad file is located near
    the orign (0,0) before importing.
    wrote in message news:5822971@discussion.autodesk.com...
    Active Member
    01-17-2008 06:20 AM in reply to: cjclarke
    Thanks, I have Autocad LT and will give it a try.
    Active Member
    01-17-2008 08:24 AM in reply to: cjclarke
    Yes, that helped a lot. Many thanks.
    I couldn't see the import at first because the plot was huge, dwarfing the A0 title block selected. Is there something that can be done to get the information to fit the title block, or is it the other way round?
    Distinguished Contributor
    01-18-2008 03:43 AM in reply to: cjclarke
    Scale it on importing. In the Import dialog box is the Scaling section (lower left). Set the Import units: to Custom and enter a value in the Scale factor: box. You must know the scale factor. It sounds as if the DWG you where importing was in paper space and the viewport was scaled to, or the original model in model space was scaled larger than full size. Opening the DWG in AutoCAD and measuring a know distance tho determine the scale is the easiest way to get the correct scale for importing.
    Mel Persin, AIA
    AEC Technology Consultant
    Technology to Visualize and Realise Solutions
    Modeling the Future/Drafting the Past
    Active Member
    01-21-2008 02:26 PM in reply to: cjclarke
    Thanks, that worked.
