• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    Can’t edit the room tag,
    330 Views, 6 Replies
    10-04-2012 12:08 PM
    It is very confusing when it comes to edit families in the Revit. For example, the tag of the room has a “rectangle” but in the edit mode I can’t find it.
    Where might be my mistake?
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Re: Can’t edit the room tag,
    10-04-2012 12:21 PM in reply to: JamaL9722060
    This one has confused many. The most likely problem is that the Annotations are turned off in the Room Tag Family. See image below.
    Corey D.        ADSK_Logo_EE_2013.png    AutoCAD user Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    JamaL9722060
    10-05-2012 02:28 AM in reply to: CADastrophe
    Many thanks for the answer.
    but couldn't know to get the dialogue box you have provided in the screenshot?
    Firefox 20.0,
    Kaspersky 2013.
    10-05-2012 05:53 AM in reply to: JamaL9722060
    ? Visibility/Graphics Overrides is probably the most commonly used dialog interface in Revit. The default keyboard shortcuts are "VV" and "VG", or you can find it on the View tab of the ribbon, or in the View's Properties. You then have to switch to the 'Annotation Categories' tab.
    JamaL9722060
    10-05-2012 09:00 AM in reply to: CADastrophe
    Many thanks for the very informative answers.
    I check it on but still the rectangle doesn’t appear when we are the edit mode
    What might be the problem?
    Firefox 20.0,
    Kaspersky 2013.
    10-05-2012 09:27 AM in reply to: JamaL9722060
    Access the Visibility/Graphic Overrides dialog from within the Family Editor. So press "VV" while you are editing the Room Tag family.
    JamaL9722060
    10-05-2012 10:19 AM in reply to: CADastrophe
    Great! it works. many thanks for the help.
    Firefox 20.0,
    Kaspersky 2013.
