• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    Can a door family read the fire rating of a wall?
    165 Views, 2 Replies
    09-24-2012 10:16 AM
    I don't know if this is possible, but can a door family read the rating of a wall and also have it read in the door schedule? I have tried applying a shared parameter on the door family and adding it in the project. I am not understanding how I can link the two together. Please help!
    Please use plain text.
    Alfredo_Medina
    Re: Can a door family read the fire rating of a wall?
    09-24-2012 07:02 PM in reply to: maraguir
    No. That relation wall-door in regards to the fire rating is not available through parameters in the way that you have described.  A common solution is to handle this via visibility graphics, as a way to have a visual control of the fire rated values of doors and walls.
    Planta1 Revit Online Consulting | info@planta1.com
    Employee
    loboarch
    09-25-2012 06:21 AM in reply to: maraguir
    It is possible via API tools but it is all custom programming.  There is no "out of the box" solution for this.  There is a video of an AU presentation showing how this can be done at this blog site.
    http://jasongrant.squarespace.com/jason-grant-blog/week/2009-12-06-to-2009-12-12
    The part talking about what they did in the API to read the fire rating of the host wall and apply a value to the door is at about 38 minutes into the video.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
