• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Revit_Noob
    Can I "remove" an opening from a roof...?
    81 Views, 2 Replies
    10-06-2004 03:47 PM
    Hi all.... I've cut an opening in a roof - can i "fill" it back in or remove it? TIA Adam
    Please use plain text.
    *Aaron Rumple
    Re: Can I "remove" an opening from a roof...?
    10-06-2004 03:51 PM in reply to: *Revit_Noob
    With an opening? Just select the opening and delete it. With a inner loop in the roof sketch? Edit the roof sketch and delete the opening sketch. If you need the hole for existing/demo, you can draw another roof in the hole and the two roofs can then be joined with the join geometry tool. "Revit_Noob" wrote in message news:41647608$1_3@newsprd01... > Hi all.... > > I've cut an opening in a roof - can i "fill" it back in > or remove it? > > TIA > > Adam >
    New Member
    10-06-2004 04:43 PM in reply to: *Revit_Noob
    Thanks Aaron.... i'll try that.
