• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Can I apply a material for rendering to a generic wall?
    522 Views, 3 Replies
    08-19-2010 04:27 PM
    I've created some generic walls and I wanted to overide the material but I can't find a way to do it.  I thought I could do it in revit arch 2010 but using properties and edit type but I don't get the materials selection using revit arch 2011.
    Please use plain text.
    Employee
    loboarch
    Re: Can I apply a material for rendering to a generic wall?
    08-22-2010 07:22 AM in reply to: David125
    You can use the "Paint" tool to paint any material onto a surface (wall or any other).  If you want to change all the walls at one time yoju can change the appearance of the "Default Wall" material.  This is the material used by the Generic wall types.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    New Member
    08-26-2012 10:52 AM in reply to: David125
    You may insert a new layer as  a finish one ,and
     then aplly the material you want to.
                                                gerardo
    New Member
    08-26-2012 11:37 AM in reply to: David125
    In my former message I proposed you create a new finish layer , but you may also change the whole wall , jusy apply the new material to the Structure1 layer,that's  even faster.Now you have three different options.i hope someone is good for you.
                  gerardo
