• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Bizarre message re: work plane
    607 Views, 4 Replies
    04-25-2012 09:15 AM
    I have been working on this project for months (in Revit Arch. 2012) and never had a problem.  All of a sudden, I got this message -- "The work plane of this view cannot be used for this operation.  This operation should be performed in another view or the work plane of this view should be set to a Level by using the Work Plane command."
    I am in the "proposed" phase, main level, and am attempting to add a concrete slab.  The project is almost done now (a house renovation) and all has worked until now.  (The other floors have been in place for some time.)  I even tried to set it to a different plane, but am getting the same message.
    Does anyone have any idea what has happened?  Thanks in advance.
    Please use plain text.
    Active Contributor
    Re: Bizarre message re: work plane
    04-25-2012 09:26 AM in reply to: freelancette
    UPDATE! ... I re-set the work plane to Level 1 and also tried setting the view template to Arch. Plan.   I don't know which of these things worked, but I am able to add my slab now.  Very weird.
    Does anyone have feedback as to what may have gone wrong?  I have been using Revit for 2 years and this is the first time I have seen this.  Thanks.
    04-25-2012 02:23 PM in reply to: freelancette
    While in the floor plan view, someone most likely set the workplane to a different level, or the face of some object, so that they could draw some model lines in the plane of that face/level, and they just forgot to reset the workplane to the referenced level for that view.  Floor slabs (and ceilings, for future reference) require a level to be the workplane when you're creating them, unless you are doing floor or ceiling (or roof) "by face".
    Ross Kirby
    BIM Manager
    Arcturis
    Active Contributor
    04-25-2012 04:10 PM in reply to: rosskirby
    Hi Ross,
    I'm here all by my lonesome, so it would have had to be me.  After getting the message, I repeatedly checked the workplane and it was on Level 1.  I'm thinking that somehow switching it to another plane and then back again may have done the trick.  Is it possible for Revit to hiccup that way?  I must admit that there have been some slight slow-downs lately in this file ... nothing major, but some delays in orbiting/panning in some views, etc.   Are you aware of any known issues regarding error messages?
    Thank you for your suggestion!
    parveen.revit
    04-25-2012 09:02 PM in reply to: freelancette
    you might have changed the work plane in that Floor plan for some use. Now since you have set it back to respective level, it'll work fine.
    You also mentioned that your file is slowing down, To avoid this you should follow the Audit, Purge Unused, Remove unnecessary CAD and other links, delete extra views, always use Close hidden views command on regular basis and keep the geometry clean (avoid in place families wherever possible). these steps should help in increasing the speed of your machine/model.
    Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
