• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    Automatic sizing fo text
    46 Views, 1 Replies
    10-06-2004 07:16 AM
    I am new to Revit and am using version 6.1. When I am placing a wall in my drawing the dimensions are too small to read. When I try to zoom in they resize and are still too small. I looked in help to try to stop this from happening. Where do I need to go to change this setting?
    Please use plain text.
    *Scott Davis
    Re: Automatic sizing fo text
    10-06-2004 07:32 AM in reply to: quattda
    Are you talking about the "temp dims" or the permanent dimensions? Temp dims will stay the same size relative to the screen resolution as you zoom. Change your screen resolution if they are too small. Permanent dims are sized according to the scale of the view you are working in. Change the scale of the view if the dims are too small. "quattda" wrote in message news:12480219.1097072212999.JavaMail.jive@jiveforum1.autodesk.com... > I am new to Revit and am using version 6.1. When I am placing a wall in my drawing the dimensions are too small to read. When I try to zoom in they resize and are still too small. I looked in help to try to stop this from happening. Where do I need to go to change this setting?
