• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    AutoCAD LT 2007 / Logitech Setpoint issues
    199 Views, 1 Replies
    01-25-2013 10:48 AM
    I had previoiusly sent a request into Autodesk with a problem using setpoint software for my wireless mouse with Revit, starting with 2012 & 2013. this never happened with 2010 or 2011 (same mouse)
    what i sent in below and the response i recieved. anyone else have this issue? any work arounds?
    thanks.
    joshua.
    Revit Architecture 2013
    build: 20121003_2115 (x64)
    update release 2   windows 7 pro 64-bit  sp1
    processor xeon W3565 3.20GHz 3.20GHz
    RAM: 24GB
    "Issue:  worksharing monitor does not
    work when using the setpoint software for logitech peripherals.   in
    order to get the worksharing monitor to work i have to go to windows resource monitor, go to the worksharingmonitor.exe and look at the wait chain. setpoint.exe will be listed there. i need to end task the setpoint process and then the worksharing monitor will pop up. i can then restart my setpoint software for my mouse custom settings. i have to do this every time i start revit."
    the response back i recieved.
    Thank you for sending us your feedback.  I am not familiar with the software you are describing.  This is something our product support team should probably look in to.  Have you contacted them about this issue?  If not I would suggest contacting our support team and work with them to see if a resolution can be found for the issue.
    http://usa.autodesk.com/adsk/servlet/ps?siteID=123112&id=2956546&linkID=9243099
    Jeff Hanson
    Sr. Subject Matter Expert
    Revit
    Please use plain text.
    Valued Contributor
    Re: AutoCAD LT 2007 / Logitech Setpoint issues
    03-21-2013 11:15 AM in reply to: jhendershot
    Same issue with me.  Revit Architecture 2013 and Logitech Setpoint Software.  Any luck getting this resolved?
