• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    Auth code for Revit 7.0 - redundant server
    31 Views, 1 Replies
    11-11-2004 06:41 AM
    has anyone else downloaded Revit 7.0 and then tryed to get the license file for redundant server setup - and been told by autodesk that the product is not in there database yet - surely it is, otherwise they wouldn't have released it ???
    any ideas / comments please..............???
    Please use plain text.
    *Aaron Rumple
    Re: Auth code for Revit 7.0 - redundant server
    11-11-2004 07:37 AM in reply to: reubencooke
    Codes will be sent out when the CD's are pressed. 7.0 will run in trial mode with full capabilities until then. This is the way Revit has typically been released. It is put on the web a few weeks before the CD's are pressed. People have a couple of weeks to find the last few bugs. A new build is made and this is what is pressed to CD. 7.0 is quite complete in its final form, however there may be a couple of adjustments in the final build. So no one has received codes yet. But they are on the way. "reubencooke" wrote in message news:22256821.1100184131235.JavaMail.jive@jiveforum1.autodesk.com... > has anyone else downloaded Revit 7.0 and then tryed to get the license file for redundant server setup - and been told by autodesk that the product is not in there database yet - surely it is, otherwise they wouldn't have released it ??? > > any ideas / comments please..............???
