Assembly Code
4 REPLIES 4
rahimee
531 Views, 4 Replies
Assembly Code
How can i customize the assembly code according to my own code
4 REPLIES 4
smcgrady
in reply to: rahimee
e-SPECS is an application that automates and integrates your Revit models with construction specs. We have a tool that allows you to create new assembly codes and descriptions. Check out the on-line demos of it at www.e-SPECS.com.
Allenc
I couldn't find the demonstration which allowed Assembly Codes & Descriptions to be edited. Is it a stand-alone tool?
smcgrady
The e-SPECS Binding manager allows you to create new, modify and remove Assembly Codes as well as distribute the uniformatclassification.txt file. It is part of the e-SPECS for Revit application.
Allenc
Thanks, I have thew user's manual, now and see how the Assembly Codes and Assembly Descriptions can be modified.
I want to sort the exported data in Masterformat order. The Keynotes would appear to allow me to do this but I would want to edit the RevitKeynotes_Metric file. Is it safe to do this?
How many characters can the Description field hold?
Rail Community
