• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Arc walls
    94 Views, 2 Replies
    08-16-2004 01:29 PM
    I want to create an arc wall that starts with 12 meters heght and ends with a height of 8 meters.
    How is it possible to create something like that?
    Please use plain text.
    *Aaron Rumple
    Re: Arc walls
    08-16-2004 02:18 PM in reply to: mthemelis
    Draw the wall in plan. Go to the elevation and draw a slopping ref. plane from one end of the wall to the other. Select the wall. Use Top/Bottom - Attach - Pic the Ref. Plane. You can move and rotate the ref plane later to modify the slope. "mthemelis" wrote in message news:33359346.1092688217055.JavaMail.jive@jiveforum2.autodesk.com... > I want to create an arc wall that starts with 12 meters heght and ends with a height of 8 meters. > How is it possible to create something like that?
    Re: Arc walls
    08-18-2004 10:58 AM in reply to: mthemelis
    Ok thank you!
