• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    info
    An error has occurred while drawing the contents of this window
    983 Views, 6 Replies
    09-22-2011 08:01 AM
    After using the program for a few weeks it appeared the error message "An error has occurred while drawingthe contents of this window" only when I open the 3D view. I reset the Windows user profile and everything is back to normal operation. Today has come out again this error screen. Video drivers are certified and the board is a Nvidea Quadro and normally I have no problems. To test I created a new user and everything works fine.What could alter the software related to user profile? Thk!
    Please use plain text.
    Product Support
    Chris.Aquino
    Re: An error has occurred while drawing the contents of this window
    09-22-2011 03:39 PM in reply to: info
    If you have not already, I would try disabling (or enabling, if already disabled) Hardware Acceleration in the Revit Options.
    I would also try clearing out the Temp folder on the machine. You can do this by hitting Windows+R, entering %temp%, then clearing out as many files as you can.
    Chris Aquino
    Revit Support Specialist
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
    Member
    info
    09-22-2011 11:54 PM in reply to: Chris.Aquino
    If I disable the hardware acceleration works but is not the solution, we work with very large projects and we have to use the video card acceleration. I have tried deleting temp files but does not work. thanks
    Member
    info
    09-26-2011 03:16 AM in reply to: info
    anyone can help me?
    Member
    info
    09-26-2011 03:36 AM in reply to: info
    I have seen that the error occurs simply by clicking a family because it can not display the graphic in the upper left "property" with the type of item eg. wall.
    Thk.
    New Member
    12-01-2012 12:05 AM in reply to: info
    anyone can help me?????????? plzzzzzz....
    Member
    01-09-2013 05:35 PM in reply to: sadhumon916
    I am having this problem too.  Only one user has the problem.
