• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Ricardo-Maturana
    Re: Adaptive points to control a circle
    12-05-2012 06:12 AM in reply to: dcormack
    Use reference lines for both, then select them and create solid. You can as parameters and you are set. I did a water slide this way. I drew a 3d spline with circular sections. I did have to add a section at each control point of the spline. Ricardo A. Maturana Twitter: @rmaturana
    Please use plain text.
    Active Contributor
    dcormack
    12-05-2012 07:15 AM in reply to: Alfredo_Medina
    Yes that works OK for me now. Divide and repeat doesnt seem to work other than arraying unfiorm circe instances. But inserting with an instance radius param does and then manually repeat instances. Cannot figure out who to control the path - Edit proile finds a profile with grip nodes but comes up with "regeneration failure" as soon as apply is attempted. Add profile seems to add some bizare contortions.
    Alfredo_Medina
    12-05-2012 08:56 AM in reply to: dcormack
    There is a way in which Divide & Repeat can use different sizes of the repeater, and there are ways to control the path of the snake with adaptive points as well. It just requires more work, but it is possible. But if you want a smooth transition between the profiles, what I showed in my previous illustration works well, using profiles and a path. The other method with Divide & Repeat and different sizes will not create a continuous smooth form, but it will just repeat items without a transition between the items.
    Planta1 Revit Online Consulting | info@planta1.com
