• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    3d views can not be change from shaded to hidden lines.
    184 Views, 2 Replies
    03-02-2013 07:48 AM
    I tend to use my 3d views often to pan around my building.  I often go from hidden lines to shaded to wireframe but theres seems to be now way to do this now on revit 2013.  What happened?  what are the settings to fix this?
    Please use plain text.
    *Expert Elite*
    LisaDrago
    Re: 3d views can not be change from shaded to hidden lines.
    03-02-2013 04:22 PM in reply to: JHKdezine
    I am not sure I understaand the problem  you are experiencing...
    You are saying you can no longer change the visual style of your view? Is the view control tool bar missing?
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    Distinguished Contributor
    AlexDT
    03-06-2013 04:39 AM in reply to: JHKdezine
    if the viewbar is not missing, but is greyed out... you probably locked it by attaching a viewtemplate to the view.
    Properties window > Identity Data > View Template
    It should be <none> to be able to change these settings manually. If not you can either select <none> als viewtemplate or edit the viewtemplate itself. (All views that are set to this template will change).
