• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    chrisdawsonarchitect
    3d view, glass, ghosted at all times
    703 Views, 6 Replies
    07-11-2011 11:15 AM
    when in 3d view my glass (whether curtain walls or windows) is always visable through all other surfaces. see attached jpeg for a view. when i rotate it still looks like this. the vv and vg are all set to default. it is as if everything is transparent and you can see glass all the time, even when the part would not be visibl, i e the opposite side of the building as see in the attached jpeg
    Dave Franknecht
    Graduate Architect
    Chris Dawson Architect
    Harrisburg, PA
    Please use plain text.
    Employee
    Re: 3d view, glass, ghosted at all times
    07-12-2011 06:48 AM in reply to: chrisdawsonarchitect
    1.  I would first verify your graphics driver is up to date and reports no errors [similar to the image below] under Options > Graphics:
    Image Example
    2.  Next are any of the elements [such as the light gray or orange walls] overridden with Ghost Surfaces or have some transparency?  Select one of the elements > right-click > override graphics in view > by element > and verify if Ghost Surfaces is checked.
    Then verify the transparency level [if any] of the material to see if that may be contributing.
    3.  Lastly if the issue persists, try copy and pasting aligned, the walls into a blank project.  Does the same visual issue occur?
    Thank you,
    Ryan Duell
    Autodesk, Inc.
    Revit Clinic
    @revitclinic
    Active Contributor
    07-12-2011 07:00 AM in reply to: ryan.duell
    i believe my graphics card is up to date but it says it has not be tested with revit (see attached image). does this mean it is not sufficient to run revits capabilities....
    that may have soemthing to do with the material rendering palette to. when i chage a materials properties sometimes it will crash without warning... i assumed this was graphics card related.
    Dave Franknecht
    Graduate Architect
    Harrisburg, PA
    Employee
    07-12-2011 07:11 AM in reply to: chrisdawsonarchitect
    Are you running update 1 for Revit 2012?  This should improve the material crashing behavior; if needed I have included the links below:
    Revit 2012 Web Update 1 Available
    Thank you,
    Ryan Duell
    Autodesk, Inc.
    Revit Clinic
    @revitclinic
    New Member
    12-10-2012 08:07 AM in reply to: chrisdawsonarchitect
    I have the exact same issue and it is bad enough that I cannot yet use Revit 13.  Have you found a solution?
    Active Contributor
    12-10-2012 08:21 AM in reply to: john.martin
    check that you have the most up to date revit 2013 service pack and that you have graphic acceleration off
    Dave Franknecht
    Graduate Architect
    Harrisburg, PA
    Employee
    12-10-2012 08:23 AM in reply to: chrisdawsonarchitect
    This should be resolved with the latest graphics driver.  See the referenced post below:
    http://revitclinic.typepad.com/my_weblog/2012/04/glazing-appears-through-walls-in-revit-2013.html
    Thank you,
    Ryan Duell
    Autodesk, Inc.
    Revit Clinic
    @revitclinic
