• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    3D Solid from ACAD
    57 Views, 2 Replies
    08-24-2004 12:06 AM
    Hi.. i have a 3D model that was made in AutoCAD and I want to make it as a Site Component in Revit. When I imported the file, I failed to see my 3D Model. Pls help....
    Please use plain text.
    *Scott Davis
    Re: 3D Solid from ACAD
    08-24-2004 08:43 AM in reply to: hamid
    If your model in ACAD is 3D solids, you need to convert to 3D faces for Revit to read it. You can export to 3DS from AutoCAD, then import the 3DS back into AutoCAD to convert to faces. Then save, and import that into Revit, then you should see it. "hamid" wrote in message news:6925742.1093331193895.JavaMail.jive@jiveforum1.autodesk.com... > Hi.. i have a 3D model that was made in AutoCAD and I want to make it as a Site Component in Revit. When I imported the file, I failed to see my 3D Model. Pls help....
    08-24-2004 09:22 AM in reply to: hamid
    thank you very much.
