• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    3D CAD export from Revit is incorrect
    318 Views, 1 Replies
    10-02-2012 06:08 AM
    Hey everyone,
    Having a heck of a time figuring out why Revit is distorting my CAD export. I would like to get a flattened CAD file for use in Autodesk Impression. So I am placing the view on a sheet and exporting it. Please take a look at the attached images. The white background is from Revit and the black is from CAD. I've circled in red some of the obvious problems. Does anyone know why it would be coming out distorted from what I see in Revit? I'm using Revit 2012 but this also happens in 2013. Thanks
    Please use plain text.
    Product Support
    Re: 3D CAD export from Revit is incorrect
    10-04-2012 01:18 PM in reply to: michael
    To check if the issue you are seeing is specific to the project, you could try creating a new project, create some similar elements, and see if you get the same result.
    If you don't see the same result in the new project, then you can check for differences between the two projects to find what in your original project is causing the issue. The following blog posting has information on tools that may help troubleshoot the project:
    Tools for Troubleshooting Unexpected Behavior in Revit
    http://revitclinic.typepad.com/my_weblog/2012/02/tools-for-troubleshooting-unexpected-behavior-in-re...
    If you can reproduce the issue in a new project, it might be small enough that you could post it to the thread.
    Lance Coffey
    Support Specialist
    Product Support
