• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    2013 keeps crashing on me
    413 Views, 4 Replies
    12-05-2012 08:34 AM
    everytime i want to use the materials editor, revit automatically closes on me?   i installed both updates 1 and 2.  is this a graphics card problem?  if so, can i fix it?  what else can i do?
    thanks!
    Please use plain text.
    Re: 2013 keeps crashing on me
    12-05-2012 09:19 AM in reply to: johnson-carla
    You don't mention what type GC you're using but try checking your hardware acceleration Settings....If ON, then Turn it "OFF" and vice-versa.
    Mike
    Michael L. Maloney
    Virtual World Designs
    VDC & BIM Model Design, Clash & Coordination
    mike@VirtualWorldDesigns.com
    Building Design Suite Ultimate 2013
    Charlotte/Gastonia, NC & Jacksonville, Fl.
    *Expert Elite*
    12-05-2012 09:38 AM in reply to: johnson-carla
    http://www.revitforum.org/architecture-general-revit-questions/11318-why-autodesk-torturing-us-mater...
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    New Member
    12-08-2012 11:01 AM in reply to: johnson-carla
    Hi, same problem here while using ancient video driver on my nVidia Quadro FX 3600M (because any new driver crash the ancient BIOS on the HP 87110w mobile workstation)... I have found this "solution" to the problem: open Revit, open new clean file, immedietly try to open Material Editor (wait till all renderings finish - than change to text only, it will be much more speedy) and close the Material Editor. IF Revit 2013 do not crash you can close the file, open your working file and it will hold on till you exit Revit. Any new session of Revit the same ritual again... Works for me...
    Mike
    New Member
    pdawkins
    04-19-2013 01:24 PM in reply to: johnson-carla
    Wow, I also have been tormented by this bug. I have an HP 8730w Elitebook with Nvidia Quadro FX 2700M on Windows 7. I took your advice and it works for me also. I remember issues also in 3ds max 2012 that had to do with the material sample icons. Thanks,  Patrick
