programmatically zoom/pan?
I'm racking my brains on this one.  I can't seem to find a way to programmatically zoom/pan.  I know I can zoom to the extents of the selected objects, but that's not what I want.
thanks in advance, Chuck
Don't believe it's possible I would also like to save current extents, center point & zoom for the current view to re-use on another level which would put the user in the same spot.
Dale.Bartlett
I simply want to Zoom Fit in the current active view. Seems simple but again I can't find the answer. Any takers? Thanks Dale
______________
Yes, I'm Satoshi.
You could try this worked for what I needed a while ago now... http://forums.augi.com/showthread.php?106364-lower-amp-upper-bounds-of-the-current-window-view
Imports AC_App = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Interop
Public Class FloorSurferView
    Private pMax As Point3d
    Private pMin As Point3d
    Public Sub New()
        SaveView()
    End Sub
    Private Sub SaveView()
        Dim ed As Editor = AC_App.DocumentManager.MdiActiveDocument.Editor
        Using acView As ViewTableRecord = ed.GetCurrentView()
            Dim pCenter As Point3d = New Point3d(acView.CenterPoint.X, acView.CenterPoint.Y, 0)
            pMin = New Point3d(pCenter.X - (acView.Width / 2), pCenter.Y - (acView.Height / 2), 0)
            pMax = New Point3d(pCenter.X + (acView.Width / 2), pCenter.Y + (acView.Height / 2), 0)
        End Using
    End Sub
    Public Sub Zoom()
        Dim app As AcadApplication = CType(Application.AcadApplication, AcadApplication)
        Dim lower() As Double = New Double() {pMin.X, pMin.Y, pMin.Z}
        Dim upper() As Double = New Double() {pMax.X, pMax.Y, pMax.Z}
        app.ZoomWindow(lower, upper)
    End Sub
End Class
Dale.Bartlett
Thanks for the reply, but I need this for Revit (2013). Regards, Dale
______________
Yes, I'm Satoshi.
jeremytammik
Hey guys,
you seem to have missed my last post:
http://thebuildingcoder.typepad.com/blog/2012/06/uiview-and-windows-device-coordinates.html
The UIView class provides full support for pan and zoom. That is what it is there for, as far as I can tell.
Best regards,
Jeremy
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thanks, Jeremy!
