hide form and get input
How do I hide a form and get input from the user. Is this case I need XYZ coordinates from the screen. Thanks.
Paulio
Get the current UIDocument then use UIDoc.Selection.PickPoint
Joe.Ye
In a button click handler, set the form's DialogResult to DialogResult.OK, or Cancel.
      DialogResult = DialogResult.OK;
The the form will be hidden.
In the Revit Execute() method, after the code of ShowDialog(), call Selection.PickPoint() to ask the user to pick a point.
After the PickPoint() method, you can show the dialog again. The coordiantes of the point picked by calling PickPoint() is Revit model coordinates system.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
