Passing 'Angle' value to instance 'Angle parameter type
I am getting some wierd angle results when I pass an angular value (e.g. 45 degrees) stored in  'Double' variable, and passing it to re-set the 'AngleRot' instance parameter in the family.
As an example, if the the value obtained is 45 degrees then when I pass it to set the 'AngleRot' instance parameter, the family shows 1543.34567...  Some strange value!!
What is teh method for converting the Double value to an Angular value correct in C# to assign it to a Revit instance parameter of 'Angle' type...
Thanks for your help
###### CODE BEGIN  ######
double AngleDbl = 35.5;
param1 = familyinstance.get_Parameter("AngleRot");
param1.Set(AngleDbl);
###### CODE END ######
Zak
ollikat
I think you should give angles as radians for that parameter.
Hi Olikat,
Thanks for your great help. You have saved my day. I have converted the angle value from Degrees to Radians, and then passed the value to the instance parameter. That worked. Here is the line of code modified below.
double AngleDbl = 35.5 * Math.PI / 180;
Thanks - Zak
