How to use OpenSharedParameterFile Method?
Message 1 of 10
I spent whole afternoon trying to figure out how to use OpenSharedParameterFile Method...It seems easy, but when I debug the code, it always give me
"Error in readParamDatabase", it's internal exception..anybody know how to solve that?Smiley Sad
Really drive me crazy!
Thanks for any reply..T T
Here is my code:
string fileName = @"C:\Users\Administrator\Desktop\revit\w1\try\" + datefromuser + ".txt";
FileStream fs = File.Create(fileName);
commandData.Application.Application.SharedParametersFilename = fileName;
try
SharedParameterFile = commandData.Application.Application.OpenSharedParameterFile();
catch (Autodesk.Revit.Exceptions.ApplicationException) { }
DefinitionGroup sharedParameterGroup = SharedParameterFile.Groups.Create("RevitParameters");
I want to create a new shared paramter file and try to add some shared parameter..
Replies (9)
Message 2 of 10
ollikat
Hi
Could it be that file stream that is returned has "locked" the file for it self. At least File.Create documentation says this:
"The FileStream object created by this method has a default FileShare value of None; no other process or code can access the created file until the original file handle is closed."
Hope this helps.
Message 3 of 10
Thanks for the answer, Finally I find the problem...it's because my shared parameter file is empty....T T..spend me so much time....
Message 4 of 10
1368026189
Hello  cjl0411
         you still active here? I got the same question for a different reason, would you please give me your email and  help me out? thanks a lot!
         shrl007@163.com
Message 5 of 10
1368026189
@Jeremy Tammik
It works well sometime but sometime it doesn't work!
app.OpenSharedParameterFile() get a null as return!
Message 6 of 10
rita.aguiar
@1368026189  @Anonymous  @ollikat
I have a similar issue.
Does anyone know what could be causing this?
The Revit document already has a Shared Parameter file. I just wanted to use its parameters so I was trying to open it with the OpenSharedParameterFile method.
Many thanks.
Message 7 of 10
rita.aguiar
The thing is, app is null because it is defined in the first method, while the open shared parameter file is in the second method:ShareParameter file 3.png
Message 8 of 10
ollikat
So...seems to me that you have managed to figure out issues in your code. Or is there still something?
Seems to me, that you are new to C#. I would guess that you will face many similar issues, and probably the problem will not be the Revit API, but the programming environment in general. For those issues google & stackoverflow is your best friend. Detailed instructions to not Revit API specific issues aren't necessary provided here.
Message 9 of 10
rita.aguiar
thanks @ollikat , I didn't realize at first it was a C# programming question. Do you have any suggestions on what keywords to search for on google?
Message 10 of 10
ilgnv88
It may be too late, but if anyone has a similar problem, please pay attention to the encoding used for the shared parameter file
