• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit API
    Active Member
    Get Command ID from Journal
    170 Views, 2 Replies
    10-12-2012 12:57 PM
    I give up.  I've spent a good amount of time on Google and maybe it's just because it's Friday afternoon, but I cannot find my answer.
    I am trying to play with 2013's ability to replace built-in commands.  I see that I can look through the journal file to get commands.  I also found a nice Excel sheet that listed a lot of the command IDs already.  The Command ID I am looking for does not seem to be in the Excel file, and looking through the Journal file gives me no help in figuring out what the command ID is.
    I am specifically flooking for the Add a Leader under Symbol command, but would love to know how to determine it myself.
    Please use plain text.
    Employee
    saikat
    Re: Get Command ID from Journal
    10-12-2012 02:36 PM in reply to: jkunkel
    I investigated a bit into this and found the following entry in the Journal file for the Add A Symbol button click:
     Jrn.PushButton "ToolBar , {}{} , Dialog_Family_FaminstLeaderDlgbar" _
              , "Add a Leader, Control_Family_FaminstAddleader"
    From what it seems, many Revit actions are not performed using commands - actions can be taken directly in controls which seems to be happening here. So it seems we cannot get/use the CommandId to replace this functionality.
    If you need a workaround, I am thinking if you can use the IUpdater mechanism to track for newly added symbol and take some steps as appropriate.
    cheers
    Saikat Bhattacharya
    Active Member
    10-15-2012 06:40 AM in reply to: saikat
    I had found that line in the Journal as well, I just assumed that I didn't know how to translate it.  Sadly, not the case!
    I will do some reading into the IUpdater.  Haven't used that yet.  Thanks!
