C# - Loop with TextNote Type not working.
mfleming.stantec
mfleming.stantec
Hi.
I'm working on a simple add-in that creates a bunch of text styles in a project or family in Revit 2013.
I'm able to only duplicate and add 1 text type and modify it's text parameters.  I'm trying to figure out how to loop it based on an array count.
I want to count & loop depending the the array count for "txtHgt".
But I cannot add a variable counter to "noteType" which is a TextNoteType and this is causing the issue.
                // Action Code Starts Here
                Document doc = commandData.Application.ActiveUIDocument.Document;
                /// Retrieve access to all TextNote Elements
                FilteredElementCollector collectorUsed
                  = new FilteredElementCollector(doc);
                ICollection<ElementId> textNotes
                  = collectorUsed.OfClass(typeof(TextNote))
                    .ToElementIds();
                foreach (ElementId textNoteid in textNotes)
                    TextNote textNote = doc.GetElement(
                      textNoteid) as TextNote;
                    Transaction trans = new Transaction(doc);
                    trans.Start("ChangeParam");
                    //Setting the Variables
                    string txtOPR = "_";
                    string[] txtHgt = { "2.38mm (3/32in)", "1.98mm (5/64in)" };
                    string[] txtbkgd = { "Op", "Tr" };
                    //string txtType = (txtHgt[1] + txtOPR + txtbkgd[1]);
                    //int txtCount = txtHgt.Count;
                    int txtCount = 1;
                    for (int i = 0; i < txtCount; i++)
                       // for (int i = 0; i < list.Count; i++)
                        //string txtvar = list[i] as string;
                        //Element num = textNote.TextNoteType.Duplicate(txtvar);
                        //TextNoteType noteType4 = num as TextNoteType;
                        string txtType = (txtHgt[i] + txtOPR + txtbkgd[1]);
                        // Create a duplicate
                        Element ele = textNote.TextNoteType.Duplicate(txtType);
                        TextNoteType noteType = ele as TextNoteType;
                        // Change font parameter
                        if (null != noteType)
                            // Text Colour (only able to modify RGB Red)
                            byte valRed = 0; //Set colour to black
                            //noteType.get_Parameter("Color").Set(4);
                            noteType.get_Parameter("Color").Set(valRed);
                            // Text Line Weight 1-16
                            noteType.get_Parameter("Line Weight").Set(2);
                    trans.Commit();
                // Return Success
Any Suggestions?
saikat
Hi
I think the problem is with the count in the loop. You should change the code to -
//Setting the Variablesstring txtOPR = "_";
string[] txtHgt = { "2.38mm (3/32in)", "1.98mm (5/64in)"};
string[] txtbkgd = { "Op", "Tr"};
//string txtType = (txtHgt[1] + txtOPR + txtbkgd[1]);//int txtCount = txtHgt.Count;inttxtCount = 2;
for (inti = 0; i < txtCount; i++)
//string txtvar = list[i] as string;//Element num = textNote.TextNoteType.Duplicate(txtvar);//TextNoteType noteType4 = num as TextNoteType;stringtxtType = (txtHgt[i] + txtOPR + txtbkgd[i]);
// Create a duplicateElementele = textNote.TextNoteType.Duplicate(txtType);
TextNoteType noteType = ele asTextNoteType;
// Change font parameterif (null!= noteType)
// Text Colour (only able to modify RGB Red)byte valRed = 0; //Set colour to black//noteType.get_Parameter("Color").Set(4);
trans.Commit();
After the above changes, I can see both the textnote types created:
Hope this helps.
cheers
Saikat Bhattacharya
Senior Manager - Technology Consulting
mfleming.stantec
The loop is now working.
I'm trying to adjust the loop count based on the number of possible text sizes.
I'm using the following:
                    string[] txtHgt = { "1.58mm (1/16in)", "1.98mm (5/64in)", "2.38mm (3/32in)", "3.17mm (1/8in)", "4.76mm (3/16in)", "6.35mm (1/4in)", "12.7mm (1/2in)" };
                    int txtCount = txtHgt.Length * txtbkgd.Length;
 Which works fine.
The next part is changeing the txtType "string value based on the specific location of the count.
I want to be ablt to change the entered Text Style Type Name after I have completed all possible values for txtHgt & txtbkgd[0].  After I enter those, I want to enter txtHgt & txtBkgd[1].
I'm using the following statement.
                        if (i <= txtHgt.Length)
                            string txtType = (txtHgt[i] + txtOPR + txtbkgd[0]);
                        else
The name 'txtType' does not exist in the current context Error:
Which is saying it's outside the current scope or not defined.
What am I missing?
Matt
mfleming.stantec
I have completed the project.
Not 100% clean, but it works.
I had to add some if statements to check for values and increase array values as needed.
Completed code.
using System;
using System.Collections.Generic;
using System.Collections;
using System.Windows.Forms;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System.Text;
using System.Linq;
namespace CreateTextType
    [Transaction(TransactionMode.Manual)]
    public class cmdTextType : IExternalCommand
        public Result Execute(ExternalCommandData commandData,
                                ref string message,
                                ElementSet elements)
            try
                    .ToElementIds();
                    int bkgCount = 0;
                        if (i < txtHgt.Length && bkgCount == 0)
                            bkgCount = 0;
                        else
                            if (bkgCount == 0)
                                i = 0;
                            bkgCount = 1;
                            if (i == txtHgt.Length && bkgCount == 1)
                                //break;
                                goto IfDone;
                        string txtType = (txtHgt[i] + txtOPR + txtbkgd[bkgCount]);
                            noteType.get_Parameter("Text Size").Set((3.0 / 32.0) * (1.0 / 12.0));
                            // Text Tab Size for 3/32" = (3.0 / 32.0) * (1.0 / 12.0)
                    IfDone:
                    trans.Commit();
                // Return Success
                return Result.Succeeded;
            catch (Exception ex)
                // Failure Message
                message = ex.Message;
                return Result.Failed;
