BooleanOperationsUtils.ExecuteBooleanOperation throws InvalidOperationException
FRFR1426
FRFR1426
I'm trying to compute the intersection between two solids (one coming from a wall, one I'm creating myself withCreateExtrusionGeometry). It works fine for the majority of walls, but on some, ExecuteBooleanOperation throws an InvalidOperationException :
GeometryElement geometryElement;
using (var options = new Options())
    geometryElement = wall.get_Geometry(options);
Solid wallSolid = null;
foreach (GeometryObject geometryObject in geometryElement)
    wallSolid = geometryObject as Solid;
    if (null != wallSolid) break;
using (Solid box = GeometryCreationUtilities.CreateExtrusionGeometry(curveloops,
        XYZ.BasisZ, height))
        intersection = BooleanOperationsUtils.ExecuteBooleanOperation(box, wallSolid,
            BooleanOperationsType.Intersect);
The only characteristic of the walls in question is that they are not parallel to the X and Y axes.
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Joe.Ye
I don't think parallel is the key cause. Can you make sure that the two solids are not null?
This this doesn't solve the issue, please upload a minium code project and a rvt model file to reproduce the issue.
Thank you!
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
FRFR1426
Hi Joe,
The two solids are not null. Here is an external command and a .rvt file for reproducing the issue: https://docs.google.com/file/d/0B_UzIApsl084RkE4ZWpxdC13cHM/edit?usp=sharing
Maxence DELANNOY
Manager
http://wiip.fr
Joe.Ye
The link seems not valid. Please fix this.
Thank you!
Joe Ye
Contractor
FRFR1426
The link work for me. Please try this one:ftp://autodesk:VJitvmbob36QtlCrGamu@wiip.fr/BooleanOperationsTestCommand.zip
Maxence DELANNOY
Manager
http://wiip.fr
Joe.Ye
With the shared model and code, I can reproduce the problem. the code itself looks no problem. Reported this to the internal engineering team.
Joe Ye
Contractor
