• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit API
    Member
    corey.schiller
    Automate exporting NWC files?
    305 Views, 6 Replies
    05-10-2012 09:12 PM
    As my first forray into the Revit API, I want to be able to automate the process of saving out NWC files from various views in a project.  If possible I'd like to script this, so that it can be done on a schedule, say daily at a certain time.
    Is this possible without too much time and effort?
    What would be the best approach to tackle something like this?
    Where can I find sample code to get me going?
    Thank you!
    Please use plain text.
    Active Member
    m.p.diker
    Re: Automate exporting NWC files?
    05-25-2012 12:53 AM in reply to: corey.schiller
    Yes that can be done. I've seen a class in AU about it.
    It's a little bit messy as it involves using journal files and windows task scheduling. If I can find the link (when at home) I'll pass it to you!
    Member
    corey.schiller
    05-25-2012 05:40 AM in reply to: corey.schiller
    Yes, if you can find that info it would be much appreciated!
    Active Member
    m.p.diker
    05-26-2012 08:24 AM in reply to: corey.schiller
    Here you go..
    http://au.autodesk.com/?nd=class&session_id=9039
    CR3220 Automating Autodesk® Navisworks® Clash Reports
    Distinguished Contributor
    09-04-2012 06:17 AM in reply to: m.p.diker
    Messy isn't the word for it. If I remember correctly they were using DWF files because of a dialog that kept coming up. And their report may have been a text file or something, no images in any case.
    Member
    corey.schiller
    09-04-2012 06:42 AM in reply to: corey.schiller
    Thanks for the reply, unfortunately I don't have an AU subscription..
    ADN Support Specialist
    09-06-2012 08:09 AM in reply to: corey.schiller
    Hi Corey,
    Anybody can sign up for the AU site to access to the class materials from the AU in the past.  Feel free to register for it.
    As to the original question about API for exporting NWC, that feature is an addin coming from Navisworks product.  No API within the Revit for that. We have a wish to make it accessible through API, however.
    Technically speaking, it is possible to write your own using Revit API and Navisworks NWcreate API. But it will involve quite a lot of coding, I'm sure.
    Mikako Harada
    Developer Technical Services
    Autodesk Developer Network
