• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Quantity Takeoff
    New Member
    p.dohmen
    qto crashes when printing with pdf
    329 Views, 1 Replies
    01-05-2012 01:55 AM
    first qto (german version) had a problem with opening pdf.
    after hotfis it crashes when printing with pdf behind.
    anyone who has a solution?
    cant even export as a new pdf...
    thx
    Please use plain text.
    Product Support
    Re: qto crashes when printing with pdf
    02-14-2012 11:57 AM in reply to: p.dohmen
    p.dohmen,
    Hello. Thank you for the post. This is likely corrected in the QTO hotfix 2. Install Hotfix 1 and 2 and then try to open the file. The Hotfix 2 has corrected some PDF conflicts. Based on your submission, this could be your solution.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18403022&linkID=10381885
    Thank you for participating in our community!
    David Dembkoski
    Product Support Specialist
    Autodesk Product Support
