• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Quantity Takeoff
    New Member
    bigtimer14785
    Ungroup after save
    938 Views, 4 Replies
    06-29-2012 07:32 AM
    I am using quantity takeoff to record measurements from 2d PDFs. When using the program I can take measurements and then organize them into groups.
    The next day when I open my project back up, All the groups remain, but are empty. All the takeoffs I created are all on the top level in the takeoff tree.
    Any ideas on how to stop this from happening?
    Please use plain text.
    Valued Contributor sta
    Valued Contributor
    sta
    Re: Ungroup after save
    09-20-2012 08:47 AM in reply to: bigtimer14785
    I am having the same issue and have searched the internet and came up with nothing. It is like my project never saved, however the file has a time stamp that says otherwise. If you figured it out let me know!
    New Member
    bigtimer14785
    09-20-2012 09:04 AM in reply to: sta
    Sorry, I never found a fix. I have resorted to uniquely naming each wbs measurement instead of creating groups. The last time this happened I lost a whole day if work. It's hard to take those kind of chances. Sent from my iPhone
    Valued Contributor
    sta
    10-01-2012 10:50 AM in reply to: bigtimer14785
    It appears the hot fix for the 2013 QTO fixed this issue
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20400244&linkID=10381885
    Active Member
    10-31-2012 10:39 AM in reply to: sta
    I am so excited to see this hot fix... It works perfectly!
