Autodesk Quantity Takeoff
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
QTO 2013 File Types and Maz Size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have crashed several times this morning while using QTO 2013. I am using DWFx files. The 3D is 900 kb, the 2D sheets are 17 mb and the QTO is 25 mb. I am using a Lenovo w520 with 8 gb RAM. I am using build 6.0.78.0 .
What is prefered for QTO 2013, DWF or DWFx files?
What file sizes cause issues?
Thanks!
David Hough
LeChase Construction
Re: QTO 2013 File Types and Maz Size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear autodesk14606
We recommend DWF files over DWFx files as they are generally smaller and load faster:
http://docs.autodesk.com/QTO/2013/ENU/QTO_Help_Fil
Regarding the crashing. I checked the crash reports that you had sent, and I suggest checking if turning off hardware acceleration improves stability. This is explained in the following article:
3D Model graphics do not appear and may cause the application to hang.
http://usa.autodesk.com/getdoc/id=TS13860865
If so, I would try updating your graphics driver from the card’s manufacturer’s webpage. Alternatively, if you have other Autodesk products installed, I would suggest downloading a certified driver recommended for one of your other applications. You can find the certified hardware page:
- http://usa.autodesk.com/adsk/servlet/syscert?id=18
If the project is complex, I would try the suggestions from the following help topics page on managing project size:
I also recommend turning on the “Auto Save” function so that periodically the application saves a backup of your work in case a crash occurs. This setting is found in the preferences as described here:
Best regards,
John Lipp
Support Specialist
Product Support
