• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Quantity Takeoff
    Valued Contributor sta
    Valued Contributor
    sta
    Manual Take-off Unable to Calculate Slopes and/or Angles
    649 Views, 1 Replies
    11-07-2012 07:41 AM
    It appears it is not possible to have an manual area or linear take off calculate slopes or angles? I have looked around but was unable to find a solution. Has anyone figured out how to do this or even a work around?
    Please use plain text.
    Product Support
    Re: Manual Take-off Unable to Calculate Slopes and/or Angles
    11-19-2012 10:48 AM in reply to: sta
    Dear sta
    This is not currently possible in Quantity Takeoff.  I’ve logged an enhancement request in this regard with our development group.
    As described on "Inputs allowed in forumas" page in the help, you are able to calculate angles using inputs such as asin:
    http://docs.autodesk.com/QTO/2013/ENU/QTO_Help_Files_2013/filesQTO_UG/GUID-A710876A-8AE2-40A5-BA91-4...
    However, what you are describing, it sounds like you are hoping to measure/markup the sheet or report the angle value which isn't possible.
    Best regards
    John Lipp
    Support Specialist
    Product Support
    Autodesk, Inc.
