• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Quantity Takeoff
    m9905101
    How to get classified result sort by diameter for pipe?
    977 Views, 3 Replies
    06-03-2012 07:47 PM
    hello,
    After take MEP quantity off for plumbing, I got a result, but the result is a total amount such as the length of cold water pipe is 40.383 meter. I can't get classified result, like length of cold water which the diameter is 15mm are 13 meter. Does anyone know how get classified result sort by diameter for pipe? Thanks for replying!
    Please use plain text.
    fawzimasri7137
    Re: How to get classified result sort by diameter for pipe?
    07-18-2012 10:39 AM in reply to: m9905101
    have you figured this out yet? can you please post how you did that?
    I am having the same issue, with Pipes and Fittings.  All dimenssions are lumped together.
    regards
    Valued Contributor sta
    Valued Contributor
    sta
    10-09-2012 08:17 AM in reply to: fawzimasri7137
    I am curious as well
    02-12-2013 05:00 AM in reply to: m9905101
    Have you figured it out yet?
    Lew Heifner
