• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Quantity Takeoff
    Valued Contributor
    DWF compliancy
    590 Views, 1 Replies
    08-30-2012 11:59 PM
    We are using the DWF Toolkit to generate custom DWF output form AutoCAD MEP (all the standard methods produce DWFs with unwanted entities).
    We also discovered that there are several custom xml attributes attached to dwf properties (dwf:smileytongue:roperty) (native:value, native:dataType, native:unit).
    We implemented them but importing our custom generated DWF (DWF Toolkit 7.7) aren't recognised well.
    The 3D Model is visible but none of the properties imported.
    Is there a guideline how to produce QTO compilant (ie. properties) DWF ?
    Zoltán
    Please use plain text.
    Valued Contributor
    Re: DWF compliancy
    08-31-2012 02:16 AM in reply to: Torokze
    Additional info.
    We've tried the PublishMetadata sample (DWF Toolkit) and non of the properties are recognized by QTO.
    Zoltán
