Autodesk Quantity Takeoff
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Autodesk QTO vs Civil 3d QTO
- Highlight
- Email to a Friend
Is the Autodesk QTO program the same as the Civil 3d QTO program? I have Civil 3d and I would like to learn to use it, but If the Autodesk QTO is more robust i would like to get that.
PG
Re: Autodesk QTO vs Civil 3d QTO
- Highlight
- Email to a Friend
Hi grafp,
The QTO Manager in Civil 3D is separate software from that of Autodesk Quantity Takeoff. Here is some information on QTO in Civil:
- http://beingcivil.typepad.com/my_weblog/2010/05/qt
For information on Autodesk Quantity Takeoff, you can find it here along with a trial:
- http://www.autodesk.com/qto
In Civil 3D, you are able to export out to 2D and 3D DWF files as well as export your Takeoff catalog you created through the QTO Manager in Civil 3D and import these into Autodesk Quantity Takeoff to create a project. This process is described in the following post:
Civil 3D and QTO - The Quick How To Guide
- http://doddsandends.typepad.com/blog/2010/06/civil
Please let me know if this answers your question.
Best regards
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
john.lipp wrote:In Civil 3D, you are able to export out to 2D and 3D DWF files as well as export your Takeoff catalog you created through the QTO Manager in Civil 3D and import these into Autodesk Quantity Takeoff to create a project. This process is described in the following post:
- http://doddsandends.typepad.com/blog/2010/06/civil-3d-and-qto-the-quick-how-to.html I'm still a little confused.. If I where to follow the instructions in the link above, do I need Autodesk QTO software in addition to the Civil 3d software I already have?
I want to be able to visually document what I have assigned pay items to in a drawing. So that someone can open a dwf file and see what items have been quantified. This was we can back check our quantities outside of autocad. This was an engineer who rarely uses autocad will not mess up a drawing.
thanks,
- Highlight
- Email to a Friend
Hi grafp,
The QTO Manager is built into Civil 3D and does not require Autodesk Quantity Takeoff (which is a separate application).
The posting “Civil 3D and QTO - The Quick How To Guide” shows how you can export the takeoff information you created in Civil 3D to import into Autodesk Quantity Takeoff. Yes, to follow the process from the post, would require you to have both applications. However, you are able to generate your takeoff information and create reports in Civil 3D using the QTO Manager without having Autodesk Quantity Takeoff installed. I included the blog posting as your question was regarding the two applications.
Here is a tutorial on the Quantity Takeoff tool built into Civil 3D:
- http://docs.autodesk.com/CIV3D/2012/ENU/filesCTU/G
If you already have Civil 3D and would like to try Autodesk Quantity Takeoff, there is a trial you can download from my previous post. The getting started guide is useful as it walks you through setting up a project step by step.
http://docs.autodesk.com/QTO/2012/ENU/Autodesk%20Q
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
