Autodesk PLM 360
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
default tenant UOM config problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Inventor's content center parts which have a unit of measure of mm have a description of Millimeter.
However, the BOM UOM Picklist in PLM 360 has the unit name listed as Millimeters, with the s on the end. The result is when you try to sync a BOM item from Vault to PLM 360 using the sync tool you get the following error, if you are mapping units:
PLM/Vault synchronization on machine MOYSEPC1 failed: entity=[Hettich Wardrobe Oval Tube Anodised 048 999 Id=447431].PushEntityToSession(session=[AU 2012])
----- details -----
System.InvalidOperationException: entity=[Hettich Wardrobe Oval Tube Anodised 048 999 Id=447431].PushEntityToSession(session=[AU 2012]) ---> System.InvalidOperationException: Unknown unit type: Millimeter
at Autodesk.Plm.VaultSync.SyncClient.SyncItemProperti
at System.Linq.Enumerable.WhereSelectArrayIterator`2.
at System.Linq.Enumerable.WhereSelectEnumerableIterat
at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
at System.Linq.Enumerable.ToArray[TSource](IEnumerabl
at Autodesk.Plm.VaultSync.SyncClient.PushSyncSession.
at Autodesk.Plm.VaultSync.SyncClient.SyncItemRevision
at Autodesk.Plm.VaultSync.SyncClient.OperationManager
at Autodesk.Plm.VaultSync.SyncClient.VaultToPlm.PushE
--- End of inner exception stack trace ---
at Autodesk.Plm.VaultSync.SyncClient.VaultToPlm.PushJ
at Autodesk.Plm.VaultSync.SyncClient.VaultToPlm.Proce
Re: default tenant UOM config problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Scott,
By default your PLM 360 tenant should have Millimeter available in the Unit of Measure picklist.
Can you go to the UOM Manager in the Administration Menu / Setup / General tab and confirm? You can take the "s" off Millimeter there if necessary.
John
John Hill
Support Specialist
Product Support
