• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Active Member
    Year in Computed Field for autonumbering
    117 Views, 4 Replies
    01-28-2013 10:32 PM
    Hi Support Officer,
    I am currently setting up a new workspace and I need to make use of the computed field for auto numbering. I need the last 2 digit of the year to appear in between my auto numbering. With the script below, I managed to get MPCR000001 but I really would like the number to be MPCRYY0001 instead. The YY represent the current year and changes whenever a new year arrived.For year 2013, the autonumber will look like this MPCR130001.
    ('MPCR' + dbo.PAD_ZERO(6, convert(varchar,REQUEST_NUMBER__AUTO_INC)))
    Is there a way to do this? Really appreciate your help and advice.
    Many thanks.
    Carol
    Please use plain text.
    Product Support
    Re: Year in Computed Field for autonumbering
    01-29-2013 06:56 AM in reply to: MJ-Carol
    Carol,
    Given the limited nature of SQL scripting ( SQL scripting is for all intents and purposes limited for math calculations with in the computed field), this would not be the best way of doing it.
    I would suggest using an “on creation script” using JAVASCRIPT (which is much more flexible).
    Joe Piggee
    Support Specialist
    Product Support
    New Member
    PringaultJ
    02-20-2013 08:10 AM in reply to: MJ-Carol
    Carol, Joe,
    What you can do on the Field is to put that :
    ('MPCR' + dbo.PAD_ZERO(6, convert(varchar,ID__AUTO_INC)) + CAST(CONVERT (varchar, GETDATE(),101) as CHAR(10)))
    And for sure you will be abel to play with the convert substring ... function available on SQL
    Regards & hope this help
    Jeremy PRINGAULT
    EMEA Business Consultant
    Product Support
    02-20-2013 08:21 AM in reply to: PringaultJ
    Jeremy,
    Good call, didn't think of it that way.
    Joe Piggee
    Support Specialist
    Product Support
    Active Member
    02-24-2013 06:26 PM in reply to: PringaultJ
    Hi Jeremy,
    Thank you for the solution, really appreciate it.
    Best regards,
    Carol Mak
