• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Distinguished Contributor
    Workflow action scripts error
    79 Views, 3 Replies
    01-17-2013 03:37 PM
    I seem to be having some problems when trying to run an action script on a workflow transition. The script works fine if I use it in the 'edit' behaviour instead.
    Is there some system issue stopping workflow transition scripts from running?
    David.
    Please use plain text.
    Re: Workflow action scripts error
    01-17-2013 03:40 PM in reply to: dkeeley
    images attached
    Product Support
    01-22-2013 09:56 AM in reply to: dkeeley
    Havent seen an issue with action scripts in the workflow. What is the error message that is generated and what does the script do?
    Joe Piggee
    Support Specialist
    Product Support
    01-22-2013 03:01 PM in reply to: piggeej
    Hi Joe,
    I have been getting some support from Andrew Shaw at Autodesk support on this. It's being caused by a bug. The PLM 360 development team are investigating.
    David.
