• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Active Contributor
    danielg67
    Accepted Solution
    Views lists items in all workflow states
    100 Views, 6 Replies
    04-12-2012 05:19 AM
    Hi
    I don't know if this is the normal behavior or a bug
    In a view every item is listed in all the states it has been not only in the current state.
    I've seen this happens when the column "Workflow Step Number" is shown in the view.
    Thanks in advance for any comment about this.
    Daniel Garcia
    Please use plain text.
    Employee
    broepke
    Re: Views lists items in all workflow states
    04-12-2012 06:18 AM in reply to: danielg67
    Daniel,
    This is normal - What you're basically doing is telling it to list all the history of the items in your view.  This is true for anything in your view of "workflow" actions.  You can potentially create a filter on that by adding one of the workflow actions and then doing a filter that says "Workflow Action contains Final Approval" - showing you all the step of the approval action.
    What you probably more likley want is to turn on "current state" or "last action" from the Workflow section in that list.  That doesn't contain the history but rather just state information about the "current" state.
    Brian Roepke
    Director of Product Lifecycle Management
    Autodesk, Inc.
    Active Contributor
    danielg67
    04-12-2012 06:54 AM in reply to: broepke
    Hi Brian
    Thanks for the quick response
    Just to clarify, it's not inside the item (workflow actions tab) but in the item's list. (see image below).
    Is this what you meant?
    I just wanted to sort the items using that column (state step number), obviously it can be done putting a number in the states name so it's not a big deal.
    Daniel
    Employee
    broepke
    04-12-2012 07:00 AM in reply to: danielg67
    Putting a number in the state name is the right thing to do if you want sorting.  This is exactly why all the example workpsaces have it that way.
    The number you're looking at doesn't actually correlate to a state.  It's just a sequece of all the events that happened during the sign off.  Think of a simple workflow first
    1. Start
    2. Submit for Approval
    3. Approve
    Easy - you think that works.... But... What about the same workflow but a "reject" happended
    1. Start
    3. Reject - More Info Needed
    4. Submit for Approval
    5. Approve
    Here we see in that example - a "reject" style workflow will make your history look very different depending what the sign offs really look like.
    Brian Roepke
    Autodesk, Inc.
    Active Contributor
    danielg67
    04-12-2012 07:03 AM in reply to: broepke
    Hi Brian
    OK, now I understand the meaning of that number.
    Thanks for the help...learning a little more of PLM 360 every day :-)
    best regards
    Daniel
    Product Support
    michelle.stone
    04-12-2012 07:21 AM in reply to: danielg67
    Daniel - check out this past 'tip of the week' for another example of workflow naming best practices.
    Michelle
    Michelle Stone
    PLM Product Manager
    Autodesk, Inc.
    Active Contributor
    danielg67
    04-12-2012 08:08 AM in reply to: michelle.stone
    Thanks Michelle !
    Daniel
