• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Member
    Using BOM Total Cost to calculate other fields
    62 Views, 1 Replies
    01-25-2013 09:40 AM
    I would like to use the data field that is calculated in the BOM tab for total cost as a factor in a Computed Field Formula. A use case examples would be:
    To calculate the cost of a certain lot size, or to add additional costs to BOM costs to calculate total costs.
    How can the Total field from the BOM tab be used in a Computed Filed Formula?
    Please use plain text.
    Product Support
    Re: Using BOM Total Cost to calculate other fields
    01-25-2013 01:06 PM in reply to: lcowgill
    Lyn,
    The feature you are looking for is not available as of yet, however this feature is being worked on and you will have access to the information on the BOM tab shortly.
    Joe Piggee
    Support Specialist
    Product Support
